dmmetzger
#1 Posted : Monday, February 21, 2011 4:32:42 PM(UTC)
dmmetzger
Washes fine, but during high spin cycle emits constant hum/squeal noise. Does not do this during agitation nor low spin. Took cabinet off and sounds like it is coming from the motor up front. Possilbe the high speed motor part causing this? What is most likely cause or part to repair? Will a new motor fix this. Thanks.
Jeff / APP Team
#2 Posted : Tuesday, February 22, 2011 6:06:54 AM(UTC)
Jeff / APP Team
It could be the pump causing the noise. To test this lets remove the pump from the front of the motor, and spin it out with no water in it. See if the noise is gone. If so check and see if something is in the pump. If not then replace the pump. Here is the part number as well as a link to the parts diagram. Hope this helps.:) Part number: AP2907492
