juanrodman
#1 Posted : Monday, February 21, 2011 1:31:57 PM(UTC)
juanrodman
My Maytag Atlantis went through the fill and wash/agitate portions of the cycle and suddenly decided not to drain and spin. It is currently full of rinse water.
magician59
#2 Posted : Monday, February 21, 2011 1:36:34 PM(UTC)
magician59
First place to look is the lid switch.
juanrodman
#3 Posted : Monday, February 21, 2011 3:24:04 PM(UTC)
juanrodman
That's it alright! It works when I manually push in on the lid switch. I believe that I can get operational if I connect (with jumper) two of the wires going to the switch. There is a white (labeled neutral), black (labeled line), yellow (labeled motor) and red (labeled machine). Any suggestions? Thanks very much!
magician59
#4 Posted : Monday, February 21, 2011 6:22:14 PM(UTC)
magician59
Here's a parts diagram. You probably just need to replace parts 7 and 8.
Top replacement parts for MAYTAG MAV6300AWW WASHER, ATLANTIS | AppliancePartsPros.com
Help! Washer won't drain and spins slowly (Washer Repair)
by chevrolady 8/27/2013 2:16:26 PM(UTC)
washer won't drain and spin (Washer Repair)
by roned17 6/11/2012 8:39:12 PM(UTC)
Frigidaire Washer won't drain and spin (Washer Repair)
by Tru2Chevy 7/20/2010 1:37:27 PM(UTC)
