Both of the support rods for the lift up cook top fell off. I can't seem to get them reinstalled. The manual diagram only shows how the end of the rod goes into the range bottom. I need to know how to get the other end of the rod into the actual range top.
:confused: Originally Posted by: georgialouisa Both of the support rods for the lift up cook top fell off. I can't seem to get them reinstalled. The manual diagram only shows how the end of the rod goes into the range bottom. I need to know how to get the other end of the rod into the actual range top.
