Eric Ettinger
#1 Posted : Wednesday, December 17, 2008 1:20:57 PM(UTC)
Eric Ettinger
My washer is leaking beneath the tub. From reading the posts I suspect it is the seal. i ordered the parts from this site and upon recieving them and reading the directions I am not sure if I have the correct parts. There is a tech bulletin about a high torque transmission. I am not replacing the trans. How do I determine if I have this trans? The part number that I ordered was AP3875413 (21002237) Tub & seal kit. After removing the agitator I found I have the old hub. The new parts I recieved is the new style. Will this work or could you tell me the part number I need. Also tool part number needed.
Eric
#2 Posted : Thursday, December 18, 2008 1:08:04 PM(UTC)
Hi Eric,
The following three Technical bulletins should help to determine what is wrong and what should be done:
Bulletin# 1
Bulletin# 2
Bulletin# 3
Here are the break down diagrams for the Maytag washer Model SAV205DAWW
Maytag Tub Seal Replacement (Washer Repair)
by Bradfurt13 8/20/2013 12:14:02 PM(UTC)
Maytag tub seal assembly (Washer Repair)
by RonAnt 10/17/2011 6:26:12 PM(UTC)
