lmeade
#1 Posted : Wednesday, December 17, 2008 1:11:21 PM(UTC)
lmeade
The controls on my Kenmore DW started malfunctioning lately. Normally we have several cycle options: Pots & Pans, Normal, Water Miser, Light Wash, or Quick rinse. At this point when I push either "Normal" or "Water Miser" nothing happens...the lights do not come on. If I push the start button it defaults to "Pots & Pans" along with "heated wash". I was able to change the cycle to a light wash after it started. But it never let me select "Normal" or "Water Miser". Is this the electronic control module or is there something else that would cause this?
#2 Posted : Thursday, December 18, 2008 12:10:05 PM(UTC)
Most likely the problem is a bad control panel (aka a console). If you need the correct part number then post the color of the console.
lmeade
#3 Posted : Friday, December 19, 2008 5:04:47 AM(UTC)
lmeade
The console is black. If you can help with a part number I would really appreciate it. Thanks!
#4 Posted : Friday, December 19, 2008 10:56:52 AM(UTC)
The part number for the black console is AP3097109. Keep us posted.
