FoxCMK
#1 Posted : Monday, February 21, 2011 6:44:46 AM(UTC)
FoxCMK
After a good, long while of constant, reliable use, the timer on my Kenmore 70 Series dryer stopped advancing, requiring a manual stop.
I purchased a used timer unit on another site. The part number for the original timer is 8299784, and the used unit was a 3976577 timer, which I'd read was the correct replacement part.
I replaced the timer making sure to place all wires in their correct locations, plugged it back in and fired it up. The timer advanced and all was well.
Fast-forward 24 hours to laundry day and 20 minutes into its very first Timed Dry (not auto) cycle with an actual load, it trips the breaker. (Admittedly I thought the timer caused the problem so I put the old one back in, it didn't start, and then finally a while later thought to check the breaker. I reinstalled the used unit.)
Now this used unit will not advance, just like the original timer. The dryer still heats and works fine - it just won't shut off on its own because the timer won't advance. The schematic is taped inside, but I am not an engineer and A. don't understand the schematic and B. have no measurement tools for troubleshooting.
Just a couple more bits of info: I have only ever used the Timed Dry function to test the timer. The used timer has a black wire instead of a brown wire for the timer motor.
#2 Posted : Monday, February 21, 2011 3:42:20 PM(UTC)
According to the parts list for this model number, the correct part number for the timer is 8299784 and it never been changed. I did not find any proven cross references to any other part numbers including 3976577.
So the only correct timer is one with part number 8299784 which is APP Part number: AP3131258
Guest
#3 Posted : Thursday, March 30, 2023 3:56:52 PM(UTC)
Guest
Rank: Guest
Groups:
United States
How many different 70 series dryers are there? I can't see the model, # anymore on this unit. But it needs a timer.
