dfmemphis
#1 Posted : Wednesday, December 17, 2008 11:28:08 AM(UTC)
dfmemphis
My Kenmore electric dryer won't start. I have replaced the timer and push-to-start button, which did not fix the problem. I just ordered a thermal fuse and cycling thermostat, which I am hoping will be the solution. If that does not work, what next? Replace the motor, call someone to service, or put the dryer out of it's misery?
Thanks.
#2 Posted : Thursday, December 18, 2008 11:35:47 AM(UTC)
Blown thermal fuse is one of the most common cause of such problem. I also would recommend to clean all vents inside and outside the dryer.
