ggreen3
#1 Posted : Tuesday, December 16, 2008 11:32:53 AM(UTC)
ggreen3
Bought new door seal and bracket from Appliance pros, everything installed tight, but door wont close without major pressure. is there a smaller seal for this model??
#2 Posted : Wednesday, December 17, 2008 4:14:02 PM(UTC)
What is the part number for the door seal? How did you find it if the model number you posted does not come up?
ggreen3
#3 Posted : Thursday, December 18, 2008 12:44:25 AM(UTC)
ggreen3
Okay the model number on the tag in the diswasher is DU300xr1, when i put it in the website it referred me to Du3000xr1. The diagram on the site matched the dishwaser to a t, so i went ahead a purchased the seal based on the manuel. The part number i ordered was AP3115122.
Thanks for responding, looking forward to your take.
#4 Posted : Thursday, December 18, 2008 8:17:28 AM(UTC)
It is normal to increase the door closure force after a new gasket installation. It should lower after a few cycles with hot water and heated dry.
