rowilson
#1 Posted : Saturday, October 13, 2007 9:46:57 AM(UTC)
rowilson
Roper range/oven given to us, seems to be working fine, then issues 2 error codes out of the blue - F3 and E2 (i think), realized the oven is heating up even though we did not turn it on. Any thoughts out there? Thanks
Rose
#2 Posted : Saturday, October 13, 2007 10:41:45 PM(UTC)
Hi rowilson
In order to provide you with the most accurate information I need the complete model number of the range. You can fins it on the oven door frame or on the frame behind the bottom drawer. The model number you provided is incorrect.
rowilson
#3 Posted : Sunday, October 14, 2007 12:29:32 PM(UTC)
rowilson
Thanks Gene
model #FES330KQ
Serial #RL3022463
Rose
#4 Posted : Sunday, October 14, 2007 3:00:09 PM(UTC)
Hi Rose
The problem with your oven caused by the shorted "Bake" relay on the Electronic Range Control (ERC). To fix it the ERC has to be replaced.
Also check the resistance on the oven temperature sensor. At the room temperature it suppose to be about 1100 Ohms. If the reading is different the oven temperature sensor has to be replaced too.
- Here are the break down diagrams for the Roper range Model FES330KQ0
- The part number for the new black ERC AP2989925
- The part number for the new white ERC AP3085712
- The part number for the new oven temperature sensor AP3081560
Good luck.
rowilson
#5 Posted : Tuesday, October 16, 2007 11:43:40 AM(UTC)
rowilson
Thanks for all your help. in the meantime, is there anyway to just disconnect the oven part so that the stovetop can be used? Thanks
Rose
#6 Posted : Tuesday, October 16, 2007 5:05:02 PM(UTC)
Hi Rose
Yes, you can do it. Remove the power from the range, open the control panel and disconnect wires from the Bake and Broil terminals on the control board. Remember which wire were goes. Insulate the wires. Assemble the control panel back and restore the power.
Good luck.
