kenmore more washer will not spin or agitate. sounds like motor is humming but won't spin or agitate. coupling is fine!!!
RECHECK the coupling, If its OK, Replace the TRANSMISSION!!!!!!!!:eek:
the coupling is fine! The transmission is costly right? Is there a way of repairing the transmission?
Cheaper to just replace it, Parts ARE COSTLY!!!
yeah! Pulled gearcase and opened it up. There was a plastic piece broken in a bunch of pieces inside case.
