2 Pages12>
gabacha
#1 Posted : Friday, February 18, 2011 11:01:23 AM(UTC)
gabacha
Hi! The lights on my Kenmore 587.15102800 will blink when I attempt to run a cycle. Other than that, no noise or water, etc. What could be wrong?
Thanks,
Marie
#2 Posted : Friday, February 18, 2011 1:31:52 PM(UTC)
Marie,
You may want to start the troubleshooting from the door switches.
Open the door and remove the six screws around the control panel. Close the door and pull the control panel away fro the top of the door and up.
Check the door switches for continuity while the door is latched and unlatched. Post the results.
- The latch assembly Part number: AP3867099
gabacha
#3 Posted : Saturday, February 19, 2011 12:00:24 PM(UTC)
gabacha
Hi Gene,
Thanks for your response. I was thinking the same thing because after I posted the original question, I noticed that the lights would blink the same when I opened and closed the door.
I followed your instructions and it looks like physically everything is ok with the latch. Is it possible there is something wrong on the inside of the latch, like some connections are not being made? It is difficult to see inside.
Thanks so much!
Marie
#4 Posted : Saturday, February 19, 2011 3:46:33 PM(UTC)
Marie,
Have you checked the switches with a meter or just visually? It has to be done with an ohmmeter while the door is latched.
gabacha
#5 Posted : Saturday, February 19, 2011 4:03:47 PM(UTC)
gabacha
Oh, ok. I get it. I will do that and let you know what happens. Thanks!
Marie
gabacha
#6 Posted : Monday, February 21, 2011 9:02:56 AM(UTC)
gabacha
hi gene,
i did the following:
unplugged the maching
removed the control panel to expose the latch
disconnected the (4) wires from the latch
connected one pole of the ohm meter to the (2) connections on the right (where the white wires were) and connected the other pole to the (2) connections on the left (where the black wires were)
i did this when the door was both open and shut.
all readings were infinity (open circuit)
at this point, is it safe to say that i should replace the latch?
thanks for your help,
marie
#7 Posted : Monday, February 21, 2011 2:48:52 PM(UTC)
Marie,
There are two separated switches on the door latch. Each of them has to be tested separately.
You have to connect one of the testing probes to one of the switch terminals and the second testing probe to the second terminal on the same switch, where the wires have been connected.
With the door latched the meter should read the closed circuit (≈0 ohms) on each of the switches.
gabacha
#8 Posted : Wednesday, February 23, 2011 1:32:48 PM(UTC)
gabacha
Marie,
Hi Gene,
I tested the (2) connections on the right with each other (where the white wires were plugged in) and there was continuity. I tested the (2) connections on the left with each other (where the black wires were plugged in and there was NO continuity. Testing any other combination of the (4) connections resulted in NO continuity.
Thanks for your help!
Marie:confused:
#9 Posted : Thursday, February 24, 2011 12:35:22 PM(UTC)
Marie,
Looks like the switch on the left side is bad. It's not coming separate, so you have to order the whole latch assembly. The part number posted earlier.
gabacha
#10 Posted : Thursday, February 24, 2011 2:14:23 PM(UTC)
gabacha
cool! will do. i noticed the screws need a star shaped head to remove them. do u know if that will come with the latch or i could probably get one at the hardware store.
once again, thanks for ur help!
marie
2 Pages12>
