Blackhawk141
#1 Posted : Monday, December 15, 2008 1:13:25 PM(UTC)
Blackhawk141
we have been having problems with our oven for a while now. The preheating light will stay on for a long time before it will beep to let you know it is done. Now sometimes the oven turns on and sometimes it doesn't, when it doesn't all you smell is gas. From what I have been reading it sounds like i might need a new ignitor for the oven and a gas regulator. Since I'm going to be working on the stove, but range has a ignitor to light the range, but not all of them work. Is this also something that can be easily fixed. Thank you in advance for any help, on what part numbers I might need and how to put them in.
#2 Posted : Tuesday, December 16, 2008 12:27:58 PM(UTC)
The problem with your oven most likely caused by a weak igniter. About the top burners problem I need more specific description.
- The part number for the oven igniter is AP2150412
You have to remove the oven floor and the flame spreader to access the igniter.
