zirk12
#1 Posted : Saturday, October 13, 2007 6:27:30 AM(UTC)
zirk12
My oven controls seem to be working but the LED clock is blank. How hard is it to replace the clock on the Jenn-Air SVD48600. Also the cooling fan runs shortly after the oven is turned on and stays running long after the oven is off. I suspect a thermal switch is failed. can anyone help and advise.
Thanks.....Zirk12
BAHENDRICKS
#2 Posted : Thursday, March 27, 2008 9:32:10 AM(UTC)
BAHENDRICKS
I Just Replaced My Clock/timer Circuit Board In My Jenn Air D 156 Because It Was Intermittent Mostly Mittent, It Was An Easy Repair Once I Figured How To Get Into The Panel. 4 Small Screws Underneath And A Part Order From Appliancepartspros.com. If You Have No Clock But The Other Displays On The Same Display Work, The New Board Should Fix The Problem, I Have Replaced The Circuit Board Display On My D 156, And I Have The Same Problem, Mine Would Come On When You Slammed The Overn Door Sometimes. There Is A Short Somewhere In Our Oven, A Random Pounding On The Top Surface Will Recover Our Display For A Short Time, Long Enought To Set The Thermostat.... A Little Funkky When You Have House Guest. I Will Not Give Up To My Discredit.
