The refridge or the freezer is not cooling. The compressor does not have power. Did some troubleshooting and found no power from control board?? Any help??
You said you did not have power coming from the control board, but do you have any coming to the board. Is there any lights on the board? If the board has power coming in, but not out, then you will need a new board. Part number: AP4366538
The temp controls are lit and can change up and down if thats what you mean
Yes that is what I was talking about. So you have power to the board, but no power coming out to the compressor. Then you need to change the control board that I listed above.
