HI BELT SLIPS W/ LRGR LOAD AND I SMELL BELT BURNING- PULLED APART BELT IS LOOSE, AND HAS TENTIONER ARM ( TO 3RD PIVOT -WHEEL ) IS THERE A TENTIONER ADJUSTMENT OR MUST I IMPROVISE ONE (COULD I- i'm strapped ? ) OR ( PREFERABLY(NOT ) ORDER NEW BELT #145371 appreciate help- got any ? --- Jeff mullen
The model number you provided will not work. Can you provide the correct model number please? Thanks.
G/E-SIGNATURE 2000 = FFT-6589-80 Originally Posted by: mullen repair  HI BELT SLIPS W/ LRGR LOAD AND I SMELL BELT BURNING- PULLED APART BELT IS LOOSE, AND HAS TENTIONER ARM ( TO 3RD PIVOT -WHEEL ) IS THERE A TENTIONER ADJUSTMENT OR MUST I IMPROVISE ONE (COULD I- i'm strapped ? ) OR ( PREFERABLY(NOT ) ORDER NEW BELT #145371 appreciate help- got any ? --- Jeff mullen ANYBODY THERE ?????????
Sorry I can not get your model to work on here. However I would recommed changing the belt. The part number based on the number you posted will be on the bottow with a picture. Hope this helps. Part number: AP3867042
Originally Posted by: Jeff / APP Team  Sorry I can not get your model to work on here. However I would recommed changing the belt. The part number based on the number you posted will be on the bottow with a picture. Hope this helps. Part number: AP3867042
THANKS- I TOOK MY # ABOVE RIGHT OFF THE BELT. 145371. IS YOUR BELT # A CROSS REFERENCE, OR WRONG? DONT WANT TO ORDER THE WRONG BELT - JEFF
Originally Posted by: mullen repair  THANKS- I TOOK MY # ABOVE RIGHT OFF THE BELT. 145371. IS YOUR BELT # A CROSS REFERENCE, OR WRONG?
DONT WANT TO ORDER THE WRONG BELT - JEFF iTS MONTGOMERY WARDS/ G/E SIGNATURE 2000. MODEL-6589-80 BELT # 145371
When I entered your belt number it changed over to this one. This one should be a correct part, but if it is wrong you can return it.
what do you think , in reviewing dialog ????????
ALL INFO ALREADY IN ANITIAL CONTACTS (2) IS ABSOLUTE AND TRUE. 2HOURS INVESTED- " VOLUNTEERS" SHOULD BE PAID- WHAT IS ACTUALLY FAIR ???>??? fINANCIALLY ASIST THESE VALUABLE MEN. JEFF AAAPROGC@YAHOO.COM
