AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Need help removing control panel and front panel to get at the drain pump
I am getting an E20 msg and i believe it is the drain pump. i found some diagrams online, and it looks like i have to take off the control panel to get the front panel off but i can only find 3 screws in the detergent chamber. after removing them, i still cannot remove the panel. I need help please!!! Thank you.
Originally Posted by: jthenne I am getting an E20 msg and i believe it is the drain pump. i found some diagrams online, and it looks like i have to take off the control panel to get the front panel off but i can only find 3 screws in the detergent chamber. after removing them, i still cannot remove the panel. I need help please!!! Thank you. JT, Here are excerpts from the service manual for your unit. I've put them in order as best that I could remember, but I'm sure you'll get by with what I gave you. Good Luck, :) :) :) Removing the top panel:
1. Disconnect the washer from the electrical supply. 2. Remove the (2) screws from the rear of the top, slide the top back and lift it off.
Releasing the console:
1. Disconnect the washer from the electrical supply, remove the top panel and detergent drawer. 2. Removethe(2)screws,one on each end,holding the console to the top of the side panels.
3. Remove the(3) screws behind the detergent drawer panel.
4. Lift the(3) tabs to release the top of console from the mounting plate.
5. Roll the console forward, while lifting up to release the bottom tabs from the front panel.
6. Unplug the wiring harness from the control panel and lift the panel off.Releasing the bellows (door boot) from the front panel:
The front of the bellows is installed over the lip of the door opening in the front panel and held in place by a spring loaded wire loop.
1. Open the loading door. 2. Using needle nosepliers, startwhere thespring and wire are connected at the bottomof the bellows and pull the wire out of the groove of the bellows. 3. Pull the bellows off of the lip of the front panel.
Removing the front panel:
1. Open the loading door. 2. Using needle nosepliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows.
1. Disconnect the washer from the electrical supply and release the console. 2. Release the bellows from the front panel and remove the (2) screws holding the door safety switch assembly to the front panel. 3. On select models, disconnect the wires from the light switch. 4. Raise the front of the washer and remove the (4) screws securing the front panel to the washer base. 5. Remove the(4) screws securing the top of the panel
6. Lift up and out on the front panel to disengage it from the (4)nylon pins, two in the front of eachside panel, and lift the front panel off.
Removing the drain pump assembly:
1. Disconnect the washer from the electrical supply and remove the front panel.
Note: Some water will be left in the hoses and pump. 2. Disconnect the inlet sump from the pump. 3. Disconnect the outlet hose from the pump.
4. Remove the (2) screws, one on each side, holding the pump housing to the washer base.
4. Unplug the wires from the pump motor and lift the pump assembly out.
Washer Repair
