herman
#1 Posted : Wednesday, February 16, 2011 6:59:49 AM(UTC)
herman
when machine comes to a final stop it makes a loud screeching noise
thank you
dave
Jeff / APP Team
#2 Posted : Thursday, February 17, 2011 4:59:43 AM(UTC)
Jeff / APP Team
It sounds like you have a bad brake assembly. In order to do a proper repair you will need a new brake, stator, and snubber. Also when I change these I change the thrust bearing kit as well. This will fix your problem. If you do not repair this, it will start to slip so bad that the agitation will not work properly. Here are the part numbers you will need as well as a link to the parts diagram. Hope this helps.
Part number: AP4373023
