johnlferg2
#1 Posted : Friday, October 12, 2007 11:35:34 AM(UTC)
johnlferg2
push button it starts, release button it stops.
as long as button is depressed, unit will run but no heat, and timers do not advance
#2 Posted : Sunday, October 14, 2007 2:45:05 AM(UTC)
If you have a simple start switch without a relay, you have a bad start switch on the motor. I would pull dryer apart and stick 115 volts to pins 4&5 of the motor to confirm.
Wine Cooler starts/stops, not cooling (Refrigerator & Freezer Repair)
by GregTX 3/21/2013 6:08:38 AM(UTC)
