I had my stand up freezer door locked and one of my kids tried to open it. The plastic insert piece inside the frame of the cabinet that the door latch engages broke. Is this a replacable part? The metal door latch is fine, it is just the plastic insert piece inside the cabinet frame that is broke.
Here is your parts breakdown or at least one for a DW2 Model SearchLooks like you have to buy the entire plastic front cap Item 7 in the "Cabinet" section. At over $200.00 I would try to jiggery pokery a fix |
THIS FORUM IS DEAD!!!!!!! |
