Our Caloric oven and broiler will not light. I don't see the ignitor on either getting hot. When I set either to work from the control panel, I hear a click as if it is turning on, then a "clunK' about 10 seconds later and the on status turns off with a beep. Oven is dated from 1993. Stove top works fine and control panel works.
Most likely the problem is a bad control board. Unfortunately this part has been discontinued and is no longer available. Sounds like it's a time for a new range.
