I just purchased this GE Profile dishwasher, model PDW9200. It came with a white plastic and foam "sound upgrade" kit. I cannot figure out how to install it. The original instructions mentioned removing a brace on models not including the 9200. I wondering if I might need to do the same. Any advice? Thanks!
I solved my own problem. It turns out that you do indeed have to remove the factory installed metal plate. The instruction manual does not mention that. I took off the metal plate and it worked perfectly.
