My upper rack in the dishwasher isn't getting clean; in fact, it doesn't seem to even be getting wet. I've removed and cleaned the upper spray arm.
I've read that the food chopper could be clogging up the machine? How do I remove the lower spray arm to access and clean that area?
THIS FORUM IS DEAD!!!!!!! |
