The dryer will not start but I do have lights on the Display panel.
Ran the Diags initially and the panel displayed an "F0" code which says replace the main control board, so i did and this didn't fix anything.
When you power on the Dryer in the "normal cycle" the time display is blank (it usaually display 45 min). If I select the "timed dry" cycle there is no display as well (usually defaults to 20 miniutes).
I have verified the AC input and checked the thermal fuse, inlet thermal fuse, door switch.
Odd thing is the Diags don't work exactly as they state in the Schematic/troubleshooting guide provided in control panel housing.
i can't perform any of the individual tests like the one that will dispaly the line voltage or test the door switch. When I enter the diag mode and the lights all come on and then go out they don't come back on and if I turn the cycle knob they go out and the time display shows "C0"
I'm pretty good troubleshooting electronics and mechanical stuff but have to say I'm stumped.
Tom
