bandit571
#1 Posted : Friday, February 11, 2011 12:56:41 PM(UTC)
bandit571
Oven (bake) element burnt in two. replacement element was installed. Still no heat. Rest of stove works fine. Oven light also burnt out at same time as the element. Element did not trip breakers when it burnt in two. Reset in stove somewhere?:confused:
#2 Posted : Saturday, February 12, 2011 1:39:28 AM(UTC)
A model number may help other help you.
I am assuming that the broil relay works OK.
Some units have a hi-limit thermostat in the bake element circuit.
Usually though it is the control board that is shot, if the bake relay is on that board.
