ECJordan
#1 Posted : Thursday, February 10, 2011 12:08:12 PM(UTC)
ECJordan
The cycle pads do not light up nor do they activate the machine. All othercontrols light and appear to work fine. The control panel was replacedand did not correct the problem.
#2 Posted : Sunday, February 13, 2011 4:53:01 AM(UTC)
Here are your parts, I hope.
Replacement parts for WHIRLPOOL KUDL01ILBS6 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
See the attachment for the tech sheet
I could not find info on the given model number. The above is for a KUDL01ILBS6.
If the unit had the same symptoms after replacing the control panel then odds are that it is a control board problem.
Even when the control panel is checked with a meter, it is still a bit of a crap shot as to the cause of the problem. Just your odds would have been a bit better.
You could try the following but it is a bit of a long shot as usually plugging in a new panel will change if not solve a dirty contact problem.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
File Attachment(s):
KUDL01IL.pdf (171kb) downloaded 2 time(s).
