The burners and oven in not working. When the far left knob is turned on the display panels come on however burners are not working. Turned oven on oven does not heat up. Unit turns off once burner knobs are turned off.
Check to make sure you have 240 volts going to the unit. Unplug or turn the breaker off for half an hour or so. Perhaps it will reset.
Cannot find an 0.3 error??
I would not mess with it, should be covered by warranty and it sounds like it could be an expensive repair, perhaps a new control board. |
THIS FORUM IS DEAD!!!!!!! |
thanks for your response. I figured it could be computer circuit board. This has been happening on and off since I purchased it last November. Isn't it funny how things go out after the factory warranty goes out. Thank goodness for extended warranties
