wildjeepgirl
#1 Posted : 14 years ago
wildjeepgirl
I have a signature menu magic electric range. It is an older model with a built in hot plate on top and an outlet on top. I plugged in a flood light on the top of the range and it blew a fuse or something because the outlet does not work now and the over the stove light does not work and the plate warmer on top does not work. How do I fix this problem?
#2 Posted : 14 years ago
A make and model number may help others help you.
Model Number Locator
If it is a really old unit it may have screw in type fuses in the control panel (usually yje top lifts).
