How do I replace the drain hose? It is routed from an uncased assembly in the front of the appliance. How do I get to the connection??
The dishwasher has to be removed from the cabinet to access it. - The part number for the drain hose is AP2802212 Gene.
Not being mechanically inclined...how the heck do you remove a dishwasher from a cabinet? Isn't the drain hose supposed to be sticking OUT somewhere outside of the cabinet? Makes no sense to me.... I see no drain hose, no way to access drain hose, but am led to believe that if I take the whole thing apart, I will find the drain hose. Brilliant engineering on Bosch's part...
