Rogerchamberlin
#1 Posted : Wednesday, December 10, 2008 10:28:18 AM(UTC)
Rogerchamberlin
HOW MANY GLIDES DO I NEED ?AND DO I NEED THE FELT PADS
AND THE GLIDES? OR JUST THE FELT PADS OR JUST THE GLIDES?
is THS SS PART NUMBER FOR STAINLEESS STEEL ?
I ALSO WANT TO CHANGE THE BELT AND GET THE RIGHT ONE, THIS IS PRETTY COMMOM MAINTENENCE WHY CANT THE PART PEOPLE HELP ME?
Adam / APP Team
#2 Posted : Wednesday, December 17, 2008 3:41:30 PM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Dear Rogerchamberlin,
Sorry so late in getting back to you
According to your model number LEA60AW the following parts are required if replacing all felts, glide and belt:
[AP3885583] Glide ( 2 each needed)
[AP4054017] Felt (2 each needed)
[AP174428] Belt
Usually its best to check and/or replace all of them since they are normal wear. You might also check the drum support rollers under the back of the drum part number [AP3453184] (2 each needed )
If you still require assistance please call me at 1-877-477-7278
