yirga29
#1 Posted : Tuesday, February 8, 2011 1:01:03 PM(UTC)
yirga29
problem began with error code f09. checked hoses and pump basket for clogs.changed pressure switch.now it is tripping circuitbreaker now
sidfink43
#2 Posted : Thursday, February 10, 2011 5:26:38 PM(UTC)
sidfink43
Ouch, this is a difficult one, not because of you but because of this machine. You are going to have to check the motor and wiring to the control board, and if that checks out, try chaning the main control board.
If you buy from this site and the part does not fix the problem you can return it, see the Returns policy for details and conditions.
Guest (4)
