thermalsol
#1 Posted : Wednesday, December 10, 2008 10:07:17 AM(UTC)
thermalsol
Unit squeaks during wash cycle. Need parts and repair info.
#2 Posted : Thursday, December 11, 2008 10:04:25 AM(UTC)
Remove the rear access panel and try to pinpoint the noise. It could be the belt (if it's too dry) or the rear bearing. If the problem is the belt you can use a WD40, if the problem is the bearing then the whole outer tub assembly has to be replaced.
Here are the break down diagrams for the Maytag Neptune washer Model MAH3000AWW
