We are having to dry every load of clothes at least two times each, any idea on what coud be wrong with our dryer? Heating element? Or could it be something else? How can we tell?
The most common cause is a dirty/malfuctioning vent system.
Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load.
Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems |
THIS FORUM IS DEAD!!!!!!! |
