dnkanton
#1 Posted : 17 years ago
dnkanton
we have a ge wall oven that was flashing the f3 fault code 10 minutes after being on,we've tried shutting it off and resetting and also replaced the sensor and it is still shutting off and flashing the f3 code-it does not over heat
teramisu
#2 Posted : 17 years ago
teramisu
Our has been doing a similar type “f’g” at us, but it happens when the oven reaches at least 450+. We had the clock/sensor replaced about seven yr ago, but is no longer available.
Until we decide on a replacement oven, I found it doesn’t F me if it’s set no higher than 350 and I DON’T open the door. Altho, I haven’t tried higher, yet. FYI-- We think the sensor doesn’t like the hot steam emanating from the open oven door. Also checking the net for a replacement sensor/clock.
#3 Posted : 17 years ago
You can get your ERC repaired at stove clock repair WB19X5231
