Hello, When washing dishes, the granite countertop directly above my bosch DW gets very hot. I peaked in above the unit and there is no insulation in there. I cant tell without removing the unit if there is any insulation in the rear. I checked your parts dept and they do not have the insulation that I can order and install myself. What should I do?
Thanks,
JOhn
