I have a problem with my washer where it will not aggitate on the delicate cycle only. It will fill up and the washer will not go any further. It will spin and drain when you advance the timer manually. All other cycles seem to be okay. I replaced the timer thinking that would be the problem since it only affects washing on the delicate cycle only.
Any help will be appreciated.
