My dishwasher just suddenly stopped working....no button works on the control panel..it has power and nothing blocking the door from shutting..It was just 1 yr old in November...I just used it two days ago and now nothing!! Please help me...my seriel number is FW2112172 and model number is GU2200XTSB3
Here are your parts. Replacement parts for WHIRLPOOL GU2200XTSB3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.comWhen you say it has power what do you mean? The unit has a line cord and you checked for power at the plug? The unit has a line cord and you checked for power where the line cord attaches to the unit's wiring, with a meter? The unit is hardwired and you checked for power at the wirenuts that connect the house wiring to the unit's wiring? You checked for power at the door switches? You checked at the control board with the door switches closed? It makes a big difference, when trying to troubleshoot. A common problem with these units is the bi-metal (fuse) Item 6 in Section 2. Remove power from the unit and the fuse. Check the fuse with a meter, should be 0 ohms. If blown be sure to use the new wiring harness that comes with the replacement. |
THIS FORUM IS DEAD!!!!!!! |
I have du915pwsqo and have the same problem, tried a different control panel, nothing, replaced the door switch, nothing. if my unit has a fuse where is it, and what does it look like? thanks
