nibarmarf
#1 Posted : Monday, December 8, 2008 8:44:43 AM(UTC)
nibarmarf
I have a built in Kitchenaid fridge that started beeping constantly a few weeks ago. It was cooling fine initially, however, now it is also not cooling properly. Any suggestions? Is this something that would be covered by the year 3-6 limited warranty or is it worth getting and extended warranty.
#2 Posted : Monday, December 8, 2008 9:54:25 AM(UTC)
3 to 6 year only applicable to the sealed system (compressor, evaporator tubing, etc.) Could be covered by it but it is hard to be sure without further diagnosis.
Here are some tech sheet which may help you narrow it down by running diagnostics.
https://www.servicematters.com/d...0Sheet%20-%202306424.pdf
https://www.servicematters.com/d...0Sheet%20-%202302865.pdf
https://www.servicematters.com/d...0Sheet%20-%202306332.pdf
And here is your parts list
Model KSSC42QMS02
