My name is Blue I have a Speed Queen Front load washer & dryer Stack (commercial). I've looked every conceivable place for a serial number, up, down, inside and out. The only stamped number on the unit is on the back upper middle edge of the dryer. GH22052091 is the number but every store or site I ask or look says this number can not be found. Is it possible the unit is discontinued? We use this machine in a Hair Salon for towels and such and the 5 rib 93 1/2" Dryer Belt broke and one of two of the 3" roller wheels in the rear is loose as the bearings seem to have come out & I can not find where they went which is strange. Also the Washer when in spin cycle drains then starts to spin but stops and stays this way for the remainder of the cycle leaving the towels soaked and have to be hand wrung. I believe I can repair this machine but am having trouble finding the parts due to the Seriel Number. Also I am not sure how to trouble shoot the spin cycle, whether it is a sensor, due to the same reason. Your help would be greatly appreciated as we have to go to the laundrymat 3 or 4 time a day. Thank You:)
Sorry the Dryer on this Speed Queen is Electric. Thank You
