Getting No Current/light On The Panel Board.
Not enough details.
Gas or electric?
Brand?
Age?
Any "other" symptoms?
If you take the bottom panel off the front of the dryer, just behind the filter assembly on the vent housing is a small white part. It is the thermal fuse. That could very well be your culprit. Make sure you unplug the dryer, before you do anything. Tom ApplianceEducator.com
I agree.
RoboJoe
The Make, model etc. are in the upper right hand side of the post.
Click on the model number and AppliancePartsPros will open usually with the unit's parts breakdown or listing.
PS: Welcome to the forum. |
THIS FORUM IS DEAD!!!!!!! |
Thank you.
I guess this takes a little getting used to. LOL
