Hi everybody, I have a concern, lately we discover that we need to run a second cycle of drying to get a normal load completely dry. My question is do I need to look to change the heater and the thermostats (which ones) or do I need to look at the problem a different way ?? Thank's for your help you all, Freddy
Originally Posted by: freddyfrenchy  Hi everybody, I have a concern, lately we discover that we need to run a second cycle of drying to get a normal load completely dry. My question is do I need to look to change the heater and the thermostats (which ones) or do I need to look at the problem a different way ?? Thank's for your help you all, Freddy Freddy, The first place to start is the exhaust vent. Disconnect it from the dryer exhaust pipe, clear any lint accumulated in it and the pipe, Check and clean the rest of the venting(inside the wall)all the way out to the vent hood. Make sure the flex vent is: as short and straight as possible. Then consider the dryer, thermostats, and heater assembly. :) :) :)
