bsr1026
#1 Posted : Wednesday, February 2, 2011 11:46:33 AM(UTC)
bsr1026
The panel on the right is loose on the bottom..is that glued on..and the question is..How do i get to it..does it pry open from the side with screwdriver
RoboJoe Industries
#2 Posted : Thursday, February 3, 2011 11:09:27 PM(UTC)
RoboJoe Industries
Take the vent cover off the top front. Screws are either on top or within the vent loovers. Then take the screws out of the top of the panel and lift the panel upward to release the tabs from the slots on the sides.
Probably a tab or 2 have broken off and you'll need a new control panel frame.
