man1repair
#1 Posted : Monday, January 31, 2011 5:17:41 PM(UTC)
man1repair
Can anyone help me find manual for dishwasher model FDB520RHS2:confused:
#2 Posted : Wednesday, February 2, 2011 12:34:41 AM(UTC)
I could not find a parts listing at AppliancePartsPros which just means it does not come up on a public search. They may still be able to get parts for you if you need them.
Here is the tech sheet for this unit
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154737301.pdf
Here is a manual which should cover your unit.
http://frigidaireservicetips.com/pdfs/484_2.pdf
man1repair
#3 Posted : Wednesday, February 2, 2011 11:58:35 AM(UTC)
man1repair
Thanks for the input, but i still need help! Tried the water test from the service data sheet,but dose not work for my model. Problem is dishwasher runs for a few minutes then stops for a few minutes and so on. Checked water temp at sink 125 degree. The manual you sent shows a thermistor under the unit, but its not there on my model! I thought that would be a good place to start, please advise. Wife is asking-Do you know what the he-- your doing??:eek: :eek:
#4 Posted : Thursday, February 3, 2011 10:35:47 AM(UTC)
I am sort of stumped on this one.
Could it be that the motor is overheating?
I would open it up and check for loose/poor connections.
Perhaps try to run the diagnostics.
man1repair
#5 Posted : Friday, February 4, 2011 1:07:16 PM(UTC)
man1repair
I tried the diagnostics,but it seems not to work for my model. This is what it dose when i hold the hi-temp wash andstart/cancel pads.Fills water for 5 seconds,drains,wash led comes on/off,pots/pan led on/off.light wash led comes on/off,heat led comes on/off,and last the wash led comes on and stays on till door is opened. Have checked for loose connections,but did not find any. Checked voltage at dishwasher junction box and it reads ok with no interruptions in voltage.
Service Manual Help (Washer Repair)
by zizik 11/26/2009 11:21:47 AM(UTC)
