I believe that my oven ignitor has gone out. I would like instructions on how to replace it?
I'm assuming you are talking about the Bake igniter. Remove the oven floor and the flame spreader. Remove the two screws holding the igniter to the burner. You have to use the old mounting bracket. Be very careful while inserting the new igniter into the bracket because the coil is very gentle and do not touch the coil with your fingers under any circumstances. - The Bake igniter Part number: AP4041245
