Mojo700
#1 Posted : Sunday, January 30, 2011 9:15:58 PM(UTC)
Mojo700
I cannot get the tub to move on my GE front loader model WCVH6260FWW (there is no 0 after the F in my model number) and thanks to all the great info and help on this board, I was able to go into test mode and check for errors. I got error E42 which looks like either the motor or the inverter. I cleared the codes, I reset the control board, and still no tub movement. Did test t10 t11 and t14 and got readings of 0 and absolutely no movement of the tub or motor. I do not have an electrical tester, but it sounds like most likely the inverter? I can probably purchase a tester/meter, but I'm not familiar with how to use one, and would really like to get the machine running ASAP. Just buy an inverter? or are the odds close enough that I should test the motor to be sure? Thanks for all the help - great forum.
Brian
Mojo700
#2 Posted : Sunday, January 30, 2011 10:39:33 PM(UTC)
Mojo700
I looked up the inverter here at app and my model washer is not available, and my inverter is not the one commonly listed for GE front loaders. Mine is not plastic at all, it is entirely aluminum, and it is shaped differently so I don't think the AP4421584 is a replacement for it either. Mine is this one:
http://cgi.********.com/...ze&item=170597019738
Not sure if I can find one to replace it with? It has 3 different model numbers on it: Part # AA23580; Emerson part # X17754670; and Little Swan Part # WMAA0011000000
If the part's not available, looks like I'll need a new washing machine :eek:
tmaj9447
#3 Posted : Saturday, February 4, 2012 9:59:53 PM(UTC)
tmaj9447
i have the inverter your looking for if you still need one.:)
