:confused: My Kenmore gas oven temp is innacurate. I replaced the temp sensor in the oven - but it did not fix the problem. When setting a temp for baking - the oven indicates 200 degrees when it first lights off and shortly reaches the set temp. Of course the actual temp measured by a thermometer inside the oven indicates about 150 to 200 deg lower. I think I have a control panel problem - but am having trouble accessing the control/time panel - I can't figure out how to take the top burner cover off.
