Is there any way to disable the end of cycle buzzer on this machine?
I cannot find any info on the given model number. Following is a service manual for a couple Maytag stacked ubnits with tugk yours may be the same or close. 16000416 Maytag Stacked Washer Dryer S1000 Service Manual - ApplianceDigest.comYou will have to join the site to download the manual but it is a good site with many manuals for the appliance repair DIYer. You could just disconnect the buzzer or speaker depending on the unit. Or if you want to get a little fancier wire in an on/off switch. |
THIS FORUM IS DEAD!!!!!!! |
