gil48311
#1 Posted : Sunday, January 30, 2011 8:09:05 AM(UTC)
gil48311
I started my whirlpool wed5820sw0, then went back to it about 5 minutes later and it was off. Tried restarting and it won't. Also, the light doesn't come on when door is open. I've tested the door switch and all thermostats for continutity, and they are fine. Anyone know what might be wrong?
RoboJoe Industries
#2 Posted : Thursday, February 3, 2011 10:17:08 PM(UTC)
RoboJoe Industries
I hate to be Mr. Obvious here, but, ...are you sure you have power to the unit? LOL
Is it gas or electric?
If electric, check for burned wire at pigtail terminal block .....or tripped circuit breaker.
Also, .......could be a dropped neutral in your electrical circuit.
#3 Posted : Friday, February 4, 2011 12:47:39 AM(UTC)
Does sound like a power problem as RoboJoe said re: no interior light.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line or Neutral without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
L1 (black) to Neutral (white) is the side of the line for the motor.
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Whirlpool won't start anymore (Washer Repair)
by jjohns1993 2/16/2013 6:54:53 PM(UTC)
Whirlpool won't start (Dryer Repair)
by dan_fash 8/7/2012 3:08:01 PM(UTC)
