When you put the wet clothes into the dryer and start it there is a loud squeaking noise. I am having trouble getting the top of the dryer open and the sides off to check it out. Can you help me??? Thank You
Originally Posted by: anthony.putrino@yahoo.com  When you put the wet clothes into the dryer and start it there is a loud squeaking noise as the clothes dry the squeaking gets lower. I am having trouble getting the top of the dryer open and the sides off to check it out. Can you help me??? Can you advise me how to take the dryer top and sides off??? Thank You
Open the door and remove the screw on each side of the top part of the door frame. Most likely the problem is a worn out slide(s) on the front drum bearing (#316 on the break down diagram). Here are the break down diagrams for the GE dryer Model DPSR483GA0AAGene.
