pfopps
#1 Posted : Saturday, December 6, 2008 10:40:28 AM(UTC)
pfopps
When trying to operate the oven in the bake mode,the oven element comes on and starts to heat up but about approx 20 sec into the cycle the control panel display, Bake and the temp display goes off and the heating element goes off.The broil cycle works correctly. I checked the bake element with my ohm meter and that seems to be ok,the relay for the bake element on the relay board pulls but after about 20 sec it drops out.If anyone has any ideas of what could be causing this i would like to hear from you. thanks
kayakcrzy
#2 Posted : Monday, December 8, 2008 5:09:44 AM(UTC)
kayakcrzy
You need to replace the clock control board. There must be a relay on it that is overheating, and causing it to shut off. Tom ApplianceEducator.com
pfopps
#3 Posted : Monday, December 8, 2008 12:08:04 PM(UTC)
pfopps
Thanks for your help.I believe the bake relay you mean is on the relay board.I'll have to order one.thanks again
pfopps
kayakcrzy
#4 Posted : Tuesday, December 9, 2008 3:35:50 AM(UTC)
kayakcrzy
Good Luck. Tom
