GDL1
#1 Posted : Saturday, January 29, 2011 11:16:14 AM(UTC)
GDL1
My dryer operates but does not heat. Already tried fuse box; not the problem. Opened the front lower panel to see if the heat element is broke, but I can't tell.
Narapni
#2 Posted : Saturday, January 29, 2011 10:06:22 PM(UTC)
Narapni
I experienced similar problem with GE coinop dryer. Motor will turn but no heat. Tested elements, ok finally came down to terminals in the switch in the motor itself but cannot replace just the switch as vendors will sell only the entire motor.
Hope this helps.
Narapni
Kenmore dryer running but not heating (again) (Dryer Repair)
by Lissyl 1/17/2011 6:28:35 PM(UTC)
